Spill timing TEF20C
OZIE
Spill timing TEF20C
Post by OZIE »
How do you spill time a TEF20 without a lift pump, how do you generate the working pressure
Re: Spill timing TEF20C
Hi Ozie.
To spill time the pump you will need to remove number 1 delivery valve and spring then the diesel will flow under gravity. The delivery valve is under the adaptor that the injection pipe screws onto.
OZIE
Post by OZIE »
You are a star Sandy, am learning every day
