Wheel weight bolt
Tim188
Wheel weight bolt
Post by Tim188 »
Hi Anyone know what type/size the wheel weight bolts are for 165-188
Thanks Tim
Re: Wheel weight bolt
Hi Tim
If the tractor has red cast centres the threaded holes that hold the weight to the cast centre are either 5/8" UNC or 3/4 UNC. If the tractor has conventional steel centres the first adapter weight is held with 4 bolts and nuts 5/8" diameter not sure the length, can be UNF or UNC thread.
Tim188
Post by Tim188 »
Thanks Sandy it was the square hole in the steel wheel that was throwing me, i have bought some wheel weights and thought there would be some sort of special bolt ???
You can purchase those type of bolts, they are called CSH, cup, square, hex. The biggest problem with this type of bolt is finding a grade 5 or 8.8 strength bolt.
