35 4cyl TVO Tacho
ParryJ
35 4cyl TVO Tacho
Post by ParryJ »
Hi all, I have a 35 TVO that currently doesn’t have a tacho on it, I am looking at fitting one, does anyone know where the cable goes and what I will need in order to fit it correctly?
Many thanks
Re: 35 4cyl TVO Tacho
Morning
If your tractor is a FE 35 TVO with a 4 cylinder engine, it should have a rev counter drive connection just under the distributor or built into the bottom of the distributor. if you require parts, it will be a case of looking on the internet.
