Attaching hay bob to Furguson TE20
tonyrelle
Post by tonyrelle »
Has anyone any experience of running a hay bob on a TE20. If so is there a suitable one the TE20 can handle
Re: Attaching hay bob to Furguson TE20
I'm fairly sure it could be done, first issue would be will the tractor lift it? They're not hugely heavy but the mass isn't close to the tractor. Second is that you may need an adaptor to get the pto to fit. Third is the issue of pto out of gear = no hydraulic lift, so you would be dropping the shaft off for roading. Also, in the field the flywheel effect of the rotors will keep driving you along if you just dip the clutch without dropping out of gear.
Link to a small one...
https://www.ebay.co.uk/itm/325942489277 ... R7aSvNaYYw
