Very sadly, due to a change in circumstance's, I am having to sell my Te 20.
I have spent a lot of time, & money on it, but am now unable to finish it off.
The tractor was built in 1947, so is a very early model, & is fitted with the Continental Z120 engine. I have the dating certificate from the club to confirm this date. The tractor, as far as I am aware has not be road registered.
The original engine (included) sadly is badly cracked, however I managed to purchase of another club member a replacement engine, which I have stripped down, & can confirm that there are no cracks either internally, or externally. the engine, however does need a full rebuild, this is the only large item that needs doing.
I have restored the rear of the tractor, it is all painted, & have rebuilt the hydraulic pump.
The vast majority of other parts have been overhauled & painted.
The bonnet, fuel tank, side panels, new front grill/panel, & new rear wings still need painting.
The tractor comes with all the following new parts:
12v starter motor, & generator.
Modified generator bracket to fit the z120 engine.
New 12v wiring loom, ignition switch, voltage regulator.
new radiator, thermostat, hoses.
New carb.
Electronic ignition unit fitted to distributor, new HT leads.
New front tyres.
New front wheel bearings.
there are probably lots of other bits i have fitted, & done.
The tractor can be moved, as have made up a special frame, bolted to the bellhousing with a castor wheel, so with 3 ramps on a trailer, can be loaded.
I am not interested in breaking the tractor up, would be a shame to do so.
I am located 10 minutes from junction 19/20 M25 near watford, Hertfordshire.
£1300.00
Please dont hesitate to call if you want more info, & can help with loading, etc.
James, tel: 07778 558899
