MF35 Seat studs
Cuthbert
MF35 Seat studs
Post by Cuthbert »
I would like some advice/help regarding fitting the seat base to the hydraulic cover.
I have been unable to get studs like the original ones. I would like to know if it is possible to still get them and where from. If not, does anyone know what size they are so that I can use suitable bolts?
Thank you.
Re: MF35 Seat studs
The stud size is 1"3/4 x 7/16, UNC one end and UNF the other. You will also require 2 x 7/16 UNF nuts, UNC end screws into lift top. Have seen them for sale on eBay before.
Cuthbert
Re: MF35 Seat studs
Post by Cuthbert »
Thank you very much.
Cuthbert
Re: MF35 Seat studs
Post by Cuthbert »
Hi Sandy
Just thought I’d let you know that thanks to your help I ordered the parts from Acorn Services Tractor Parts and they are now here and fitted.
Thank you again.
Alunarndt
Re: MF35 VIN number
Post by Alunarndt »
Hi there guys, bit out of topic but I’ve got a Massey 35 and wanted to put on display for some shows
Only issue is I haven’t got the vin number to do so anyone scrapping any that I could have the vin number off, thank you as well
