Ferguson TEF20 pushrods
Post by Roadknight »
Hello,
Does anyone have any knowledge of where to get new pushrods for a diesel Ferguson TEF20, we only require one as it is the only one that is bent and the rest are fine.
Re: Ferguson TEF20 pushrods
Hi.
Have you tried to straighten it, if the bend is in the middle of the push rod put it longways in a vice and take the worst of the bend out, then do the rest with a hammer. If the bend is nearer the cup end you may have to use a little bit of heat, do not over heat. Have you found the problem that caused the pushrod to bend?.
We have now managed to source a used pushrod, the problem was one of the inlet valves sticking in place and when we removed it it was signigicantly harder than the rest and needed a blow with a hammer before being able to shift it. We beleive this was caused by a build up of carbon deposits on the stem of the valve.
