Trying to ascertain engine spec and tractors age
Engine no S134877E
VIN No TED136404
ENGINE NO'S ETC
Re: ENGINE NO'S ETC
From the serial number, TED 136404 = Mid May 1950. All that I can tell you about the engine is Standard, Petrol / T V O.
kevinfurey
Re: ENGINE NO'S ETC
Thanks for the reply
Would that be a low compression engine with an 87 m bore
kevinfurey
Re: ENGINE NO'S ETC
Re: ENGINE NO'S ETC
Going from the engine serial number the engine should be 85 mm bore, 4.8 compression, and 23.9 belt horse power.
Re: ENGINE NO'S ETC
Hi, I have a lovely old tractor and want to understand which model I have so that I can identify which battery I need to get and generally what it can do. The Vin Number is SNF231670. The tractor will not start and I am told it is the battery that needs replacing. Do you know what the model is ? Do you know the type of battery I need to buy?
Looking forward to hearing from you.
Janey
Re: ENGINE NO'S ETC
Hi.
From the details you have listed your tractor should be. Massey Ferguson 35, 3 Cylinder, Single Clutch. Year 1961.
Battery = 643.
Battery = 643.
Re: ENGINE NO'S ETC
Hi Sandy, many thanks ks for getting back to me. I'll pick one up today. Hopefully I'll be able to chain harrow this afternoon !
Jane
Jane
Re: ENGINE NO'S ETC
Battery now fitted and she started ! Fields chain harrowed this afternoon. Thank you so much.
