Hi, I have been getting a finger bar cutter for behind my tef, but has a bit of a modified end on ptoshaft with new wide yoke, and has had a bit of welding been done to it, my question is how does the pto shaft detach from the mower so I can replace the whole shaft?
Many thanks Graham
Finger bar cutter
Re: Finger bar cutter
I've also recently got a fingerbar on my TEF but they are all different i'm sure. I've got an International Harvester S4-2 mower that has recently been roped out of a shed after years of neglect but it still worked until a few bolts sheared and we had to take the pto drive wheel off. It should be pretty self explanatory to take the shaft off as there should just be a few bolts that connects it to the drive wheel.
Hope this helps.
Hope this helps.
