TE20 Lift Shaft
GuyC
TE20 Lift Shaft
Post by GuyC »
Evenign all
First post so treat me gently!
Working on refurbishing the hydraulics on a recently acquired and first Fergie.
When we got the tractor it drove, steered and stopped well but the hydraulics were immovable.
Drained the sludge that was once oil and will work to refurb the pump which is now clean.
The lift cover and arms and shaft are a different matter. Two legs broken off the lift cylinder and the whole arm and lift shaft assembly was solid. Days later and we have the arms off and shaft and bushed out but the shaft is a mess and probably nor usable.
I've tried a few places for a shaft with no luck.
Does anyone know where I can get a decent or new one or does anyone have one to sell.
Thanks for reading.
Guy
Re: TE20 Lift Shaft
Try richard@masseyfergusontractorbreakers.co.uk
A bit of minimal research says it would appear the lift arms are interchangeable with a 35, don't know if the cross shaft is though. Have you tried a Massey/Agco dealer? Could be spendy but worth a go.
GuyC
Re: TE20 Lift Shaft
Post by GuyC »
Thanks for the tip.
I’ve called a few. Drawn a blank!
I’ll try Richard though. Thank you 👍
