Hello,
In attachment the pictures from our project
Tractor is still running but needs some repairs. I would like to define the type etc.
In attachment pictures from the tractor and serial on the right side off the differential.
Is it TE 20 or a TEA 20 ?
Is the 235 the serial nr?
It has a diesel engine. Is this engine retrofitted afterwards?
I would like to order fuel filters. What would be the parts catalogue for this one?
Would be great if info is available.
Thanks & Regards
Kristof
Retrieving Type off tractor
- Attachments
- engine plate.jpg (173.55 KiB) Viewed 3363 times
- tractor view.jpg (190.37 KiB) Viewed 3363 times
- right side.jpg (141.77 KiB) Viewed 3363 times
Re: Retrieving Type off tractor
Hi Kristof.
Your tractor looks like a TEF 20 diesel, there should be a little metal strip on the dash just in front of the steering wheel with model and serial number.
This engine has a reference of 20 C when ordering parts.
The 2 fuel filters in the second picture, they should be available for most parts supplier. they may be of the paper type rather than the original felt type.
Picture 3 is the date code for when the casting was made.
Regards
Sandy
Regards
Sandy
I would agree it's a TEF 20.
The 20c diesel was an original factory fit but engines were interchangeable. If it has a 'KI-Gas' pump on the dash to the right of the steering wheel connected to a small square tank behind the dash and two battery trays near the foot plates I would say it's original.
Nice looking project.
