Starting Ted 20
Alptf
Starting Ted 20
Post by Alptf »
Hi, Can somebody please confirm how to start a Fergie Ted 20
I turn the Key, foot on the clutch and push gear lever towards S However the gear level does not engage into S like it does with the other gears, Should it click into S?
Thank You,
Alwyn
Re: Starting Ted 20
Hi,
Key on, don't really need the clutch, gear lever to S. From memory it should feel like pushing against a spring - it should not click into place and stay there!
Does the engine turn over and start?
Alptf
Re: Starting Ted 20
Post by Alptf »
Hi,
I have turned the key on, tried pushing the Gear lever into S but it just feels like I am pushing against something solid. The engine starts to turn over, but does not start.
I know the Battery is flat, so I have been using a Noco Boost pack to help turn over.
I am just not sure regarding the Gear lever going into S.
Thank You,
Alwyn
Re: Starting Ted 20
If the engine is turning over in S then in my opinion it's doing what it should.
Without a decent battery it will be difficult check what is working correctly and what isn't.
Alptf
Re: Starting Ted 20
Post by Alptf »
Ok, Many thanks, Battery is flat so I need to change that.
Thank you again.
