Hydraulics not working,
Posted: Mon Jul 06, 2026 9:50 am
by Fergi20
Hi, tractor has been standing for over thirty years with the arms in the raised position. I've removed the top cover to free off the cross shaft. I know the control valve is connected and is moving. But with the tractor running no oil is coming up to the top cover. Any ideas.
Re: Hydraulics not working,
Posted: Mon Jul 06, 2026 2:54 pm
by Hair Bear
Is the pto in gear?
Posted: Wed Jul 08, 2026 4:53 pm
by Fergi20
Hi, yes that's going round all okay. Just not pumping anything up the pipe to the top cover.
Posted: Wed Jul 08, 2026 4:54 pm
by Fergi20
Yes, that's the first thing I checked.
Posted: Wed Jul 08, 2026 7:12 pm
by Hair Bear
If the control valve is connected to the fork, and the spring etc. on the valve is all ok, then unfortunately sounds like a pump rebuild job. I've never done one so sorry can't advise on that.
Posted: Thu Jul 09, 2026 8:32 am
by Fergi20
Hi, I guess you're right. Winter job.
Posted: Thu Jul 09, 2026 2:14 pm
by Hair Bear
Well, to drop the pump out it's side panels off, reach in to disconnect the valve, remove the pto shaft, and undo the bolts. the pump and bottom plate drop straight out.
