te20 with z120 engine, sump, & oil filter tube
jamess3
Post by jamess3 »
hi, am really hoping that a member might be able to help. after having a near vary nasty accident on friday, when changing the axle stands on the front of my te20 that i am restoring, with a high lift farm jack, the jack fell over, thank god for steel toe cap boots! foot got slightly trapped under tractor, just shaken & bruised, but could of been a lot worse! however sump hit the ground & is bent, might be able to bash straight, however the oil filter tube, that screws into the central main bearing is badly bent, & split, so am desperately after a replacement, ideally along with a sump. if any member can help, i would be most grateful indeed. fingers crossed one of you fine folks can help, or point me in the direction of someone who might.
many thanks, James. 07778 558899
