MF35 Perkins 3 cylinder will not start
Smp100
Post by Smp100 »
Hi, Looking for advice…injectors working fine and fuel entering cylinders and although the engine turns over and smoke emitted from exhaust it fails to fire into life. Tried a squirt of Easy Start but had no effect. Any clues? Thank you
Grenadier24
Re: MF35 Perkins 3 cylinder will not start
Post by Grenadier24 »
Hi, just joined the forum, surprised you did not get any reply's, have you checked the engine stop rod is disengaging on the FIP?
I was going to ask a question here but it looks dormant?
Smp100
Post by Smp100 »
Hi, thank you for the response. Yes had the top off and checked all the mechanism so I’ve ruled that possibility out. I have been advised to check the fuel filter on the injector pump. Will check in the coming weeks.
Steve
